Problem on S4C+
Fynbo
Hello
I have the following problem on an S4C + Controller.
Get a boot error: startup error new cap -9.
Have tried to change almost everything in the robot, not servoboard and dclink.
I've put a new flash disk in and boot the robot, also experiments with different versions 1.80 & 2.10 & 2.18.
Does anyone have some suggestions? my best guess at present is the power supply operating main computer.
Sincerely,
Fynbo
Hi,Can you connect a console to the system and do a reboot? Then you can send me the log and I'll try to point you in the right direction.
BR frpa0 -
Hello
Yes, I can put on consol and send a log, but not today.
Have glanced with the boot as it prints. It seems that it can not make enabel chain. Everything else is booted.
Sincerely,
Fynbo
- 360 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
