Authentication Type [WebWare Server]
                    Hello-
                I am trying to set the Authentication Type in WebWare 4.6 to be Windows instead of SQL Server type.  When I enter the AD account I get a connection failed error, when I enter SA it works fine.  Does anyone have tips or advice on how to get this to work as I really need to quit using the SA account.
THANKS
            HiCan you please attach a screen dump on the error.Thanks!Lennart H0
            The user has access to the DB as sysadmin and I tried with with DOMAINusername and that did not work either...0
            Any help....0
Please read the attached instruction. It's about creating a user in SQL-server who can log in via WebWare server using Windows authentication. Perhaps it can help you...webwiz/151/WindowsAuth_SQLSever_WebWare.zip
Lennart H0
 - 363 IRC5
 - 81 OmniCore
 - 853 RAPID Programming
 - 31 AppStudio
