Calibration Parameters
i would like to know if i can get the calibration parameters from an existing backup i have of my IRB 140 robot.
Somebody lost the manipulator parameter disc, so i need to know if there is any other way to get them other than calib.id file.
Any help is very much appreciated.
Thanks!
  • You can do it, of course.
    You have a backup file.
    First, open MOC.cfg in syspar folder of the backup.
    then, Search a title, MOTOR_CALIB.
    Now, You can see all calib. data below the title.
    It looks like as followin;
    -name "irb_1" -valid_com_offset  -cal_offset 3.0879 -valid_cal_offset
