Page designation
hello mates..
I would like to open (show) a designated page, when I turn on the flex pendant (controller). Does anybody know how to do this kind of function??
thank you in advance!!
Best & Kind Regards,
spaik
  • Hello,
    you can let the system launch your application when changing the operating mode of the controller. This also works when you start-up the controller.
    On the FlexPendant, go to Control Panel/System/View on operating mode change; and enter the requested information.
    Unfortunately, it seems that there is a bug in RW5.06 Build95 and this is not working right now. I created a PDD and let you know when I have new information. (or you just give it a try; maybe I did something wrong).
    It is not possible to show a designated window of your application, only launch it.
    best regards
    Ren?
  • Hello,
    you have to enter the following in Control Panel/Systems/View on op mode change to let your application start-up automatically (when the controller starts-up):
    Dll:
    TpsViewXXX.gtpu.dll
    Type:
    ABB.Robotics.SDK.Views.TpsViewXXX
    Where XXX is the name of your app. Use TpsViewType.Static in your application to avoid that multiple instances are created.
    BR
    Ren?
