Error in Track Motion
Dear All,
I have created a system with IRB 4600 and a IRBT4004 track of length 19m.
I have created the work object also.
My robot is not positioned directly on the track, it is kept in a pedestal.
First i attached Robot to the track. then i moved the Robot to the desired position which i require.
The distance from the origin of Robotstudio to different places is shown below.
To Robot X=-701, Y=532, z=1280
Center of track  where robot is placed x=-648.5, Y= -540.0, z = 374.5
Position of Work object is X=0, Y = 0,z =400
When i teach a point in the workobject, for example P100, the value it is showing in the Home is x=665.85,y=1226.71,1223.87
But when i run the robot it is going to a position where x=613.35, y=2299.31,2129.37
i found that the problem is the origin is still in the centre of the Track only. How can i change it to the Robot.
Pls help me to solve this problem.
Regards,
Jipin Jose
