Calling a routine from Screen Maker
j_proulx
in ScreenMaker
If you create a button to call a routine from a custom screen made in Screen Maker, you need to load 3 special modules in order for it to work. The modules are located in the MediapoolRobotwareXXX optionsgtpusdk . There are two parameter files to be loaded; ScreenMakerMMC.cfg and ScreenMakerSYS.cfg. Also a system module (ScreenMaker.sys) needs to be added to the Rapid Program.
This information in not in the manuals.
Hi,I have loaded the 3 special modules and collected my screenmaker project to the controller.But I did not see any function to call a routine in the button I created.Can you show me the step please.Thanks0
Hi,Are you using RunRoutineButton control available in ScreenMaker ? If yes, set the RoutineToCall property specifying which module to be called.0
Thanks for the Info0
[QUOTE=Abhishek PM]Hi,Are you using RunRoutineButton control available in ScreenMaker ? If yes, set the RoutineToCall property specifying which module to be called.[/QUOTE]
when ever I attempt to use this, I get this error:
Dustin0 -
Never mind, I noticed after loading those config files, it threw the robot into a system failure, which I'm guessing caused that error I had there.
I had to do an I-Start, and I tried using the run routine button without loading those config files first, and it seems to work without any issues.
Dustin0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
