Making an Add-in (VSTA)
' Creates a new target in the active task and adds it to a path<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Public Sub Macro_CreateTarget()
' Check that we have an active station
Dim station As Station = Project.ActiveProject
If station Is Nothing Then
Exit Sub
End If
Dim activeTask As RsTask = station.ActiveTask
If activeTask Is Nothing Then
Exit Sub
End If
' Find an unused name
Dim targetName As String = ""
For i As Int32 = 0 To Int32.MaxValue
targetName = "MyTarget_" + i.ToString()
If activeTask.DataDeclarations.Contains(targetName) = False Then
Exit For
End If
Next
' Create a robtarget
Dim robTarget As New RsRobTarget()
robTarget.Name = targetName
' Add the robtarget to the active task
activeTask.DataDeclarations.Add(robTarget)
' Create a target associated with the robtarget and the active workobject
Dim workObject As RsWorkObject = activeTask.ActiveWorkObject
Dim myTarget As New RsTarget(workObject, robTarget)
myTarget.Name = targetName
' Add the target to the active task
activeTask.Targets.Add(myTarget)
Logger.AddMessage(New LogMessage("RobotStudio Sample: Created " + targetName + " in " + activeTask.Name))
' If the task has an active path procedure, create a new move instruction and add it
Dim path As RsPathProcedure = activeTask.ActivePathProcedure
If path IsNot Nothing Then
Dim tool As RsToolData = activeTask.ActiveTool
Dim procDef As RsProcessDefinition = activeTask.ActiveProcessDefinition
Dim procTempl As RsProcessTemplate = procDef.ActiveProcessTemplate
Dim moveInstr As New RsMoveInstruction(activeTask, procDef.Name, _
procTempl.Name, procTempl.ActiveMotionType, _
workObject.Name, robTarget.Name, tool.Name)
path.Instructions.Add(moveInstr)
Logger.AddMessage(New LogMessage("Sample Add-In: Added " + targetName + " to " + path.Name))
End If
End Sub
how about
myTarget.Transform.X = ...
myTarget.Transform.Y
In the API help you ll find an example under the section RsTarget.
Thanks for your help! It works for me.Do you also know how to convert the code below in VSTA code ?'// Sync the RobTaget to the VC.<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
myTask.SyncData("Module1/" + myTarget.Name, SyncDirection.ToController, new System.Collections.Generic.List<SyncLogMessage>());
'// Sync the path to the VC.
if (myTask.SyncPathProcedure("Module1/" + myPath.Name, SyncDirection.ToController, new ArrayList()))
Logger.AddMessage(new LogMessage("SyncPathProcedure of path " + myPath.Name + " succeded!"));
else
Logger.AddMessage(new LogMessage("SyncPathProcedure of path " + myPath.Name + " falied!"));
'// Sync the complete task to the VC.
if (myTask.SyncToController(new ArrayList()))
Logger.AddMessage(new LogMessage("SyncToController succeded!"));
else
Logger.AddMessage(new LogMessage("SyncToController falied!"));
Regards,0 -
looks like C# code. VSTA uses .NET means you can use c# as well as visual basic. i am not familiar with visual basic but it if youa re it shouldn t be that hard to to convert it to visual baisc.
apox2010-03-29 00:37:140 -
as Apox said you can create both C# and VB.NET projects in VSTA.If you want to translate the code you can try this tools that provides translations in both directions;
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
