Broken Licensing Evaluation-Updated
RussD
I am getting a message that I don't have valid licenses applied for RSOnline VIRC5, etc. despite the fact that I just upgraded to the 5.06 release versions and applied new licenses.
I did this, of course, after experiencing the same behavior with the previous versions of these products that were installed and working up until some unknown event occurred earlier today.
I understand that there is a known problem with licensing, does anyone know the workaround, or better yet, solution? I have not tampered with my clock settings.
Thomas38568,5550347222Russell Drown
If you have or previously had RobotStudio 5.0 EAP or Virtual IRC5 5.06 Alpha Build 1421 installed.
You may get a message that you don't have a valid license even though you have a valid license.
If you have this problem and have or previously had RobotStudio 5.0 EAP or Virtual IRC5 5.06 Alpha Build 1421 please send an e-mail to : softwarefactory_support@se.abb.com.
Then we will contact you and solve the problem.
Tonje Sandberg
Service Training Coordinator
ABB AB / Robotics Products0
This discussion has been closed.
- 365 IRC5
- 84 OmniCore
