Import paths to be modified
Gomez
Hello!
I'm trying and evaluating RobotStudio. I have the necessity of importing some paths from existing modules in order to modify them.
At the moment I can't find the way.. I am able only to modify targets that I have created (in the window Paths&Targets) but I can't visualize targets and tajectories from my loaded modules that have to be modified (PS: I am able to simulate the paths conteined in loaded modules).
So..does exist a way (I mean, without create an Add-in) to reach my aim?
Best regards
Best regards
Hello,Yes, that is possible. Do like this:
- In the Home tab go to "Robot System" and start a system (if you not already have a system running).
- In the Offline tab select "Load Module" and load your modules.
- Click on "Synchronize to Station" and select what paths you would like to import to your station.
- When you have pressed OK, the paths are synchronized to the station and are available for modifications.
Great! It works! Problem solved..and it was very simple :-)
Thanks a lot
Best regards
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
