Remove Targets
I have to delete (remove) a target in the path of robotstudio with C#.
I'm now using the code below to remove the target in my workobject (wobj0), but how should I delete this target in my path ?
// Instance active station.
Station stn = Project.ActiveProject as Station;
// Remove the original target.
stn.ActiveTask.Targets.Remove(myTarget);
Logger.AddMessage(new LogMessage("My_Target_1 is removed!"));
MessageBox.Show("target_1 is removed");
  • Hi
    Here is one way to do it. I guess it will help you continue on
    Per Svensson
    Consat Engineering
  • Hi,
    Thanks for your help! I tested the code that you suggested and it works like you said.
    Regards,
