Linking with TPShow and user windows
Hi...
In RAPID, TPShow function can show FlexPendant windows from RAPID. According to RAPID manual, there are only three predefined data. If I connect something to FP window, such as below:
TPShow USERMADE_WINDOW;
this USERMADE_WINDOW is te user-designed window page using FPSDK. In this case, if I would like to call this window using TPShow like above, the USERMADE_WINDOW must be defined but I don't have any idea for that. Does anybody know about this?? Please answer me thank you...
spaik
this is (unfortunately) not possible in RW5.06 release since the TPShow command is not supported (see release notes of 5.06):
RAPID instruction TPShow not working in IRC5 system
It is possible to execute the old instruction TPShow in IRC5 system, but it has no influence on FlexPendant windows.
best regards
Ren?
