Making an Add-in (VSTA)
I'm trying to make an add-in with VSTA for robotstudio by using the sample code for creating a new robtarget. When the new target is imported in robotstudio all the coordinates (X,Y,Z) are zero.
How can I change these coordinates  ?
This is the example code that I use:
    ' Creates a new target in the active task and adds it to a path<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
    Public Sub Macro_CreateTarget()
        ' Check that we have an active station
        Dim station As Station = Project.ActiveProject
        If station Is Nothing Then
            Exit Sub
        End If
        Dim activeTask As RsTask = station.ActiveTask
        If activeTask Is Nothing Then
            Exit Sub
        End If
        ' Find an unused name
        Dim targetName As String = ""
        For i As Int32 = 0 To Int32.MaxValue
            targetName = "MyTarget_" + i.ToString()
            If activeTask.DataDeclarations.Contains(targetName) = False Then
                Exit For
            End If
        Next
        ' Create a robtarget
        Dim robTarget As New RsRobTarget()
        robTarget.Name = targetName
        ' Add the robtarget to the active task
        activeTask.DataDeclarations.Add(robTarget)
        ' Create a target associated with the robtarget and the active workobject
        Dim workObject As RsWorkObject = activeTask.ActiveWorkObject
        Dim myTarget As New RsTarget(workObject, robTarget)
        myTarget.Name = targetName
        ' Add the target to the active task
        activeTask.Targets.Add(myTarget)
        Logger.AddMessage(New LogMessage("RobotStudio Sample: Created " + targetName + " in " + activeTask.Name))
' If the task has an active path procedure, create a new move instruction and add it
        Dim path As RsPathProcedure = activeTask.ActivePathProcedure
        If path IsNot Nothing Then
            Dim tool As RsToolData = activeTask.ActiveTool
            Dim procDef As RsProcessDefinition = activeTask.ActiveProcessDefinition
            Dim procTempl As RsProcessTemplate = procDef.ActiveProcessTemplate
            Dim moveInstr As New RsMoveInstruction(activeTask, procDef.Name, _
                                                    procTempl.Name, procTempl.ActiveMotionType, _
                                                    workObject.Name, robTarget.Name, tool.Name)
            path.Instructions.Add(moveInstr)
            Logger.AddMessage(New LogMessage("Sample Add-In: Added " + targetName + " to " + path.Name))
        End If
    End Sub
  • apox
    apox ✭✭
    how about
    myTarget.Transform.X = ...
    myTarget.Transform.Y
    In the API help you ll find an example under the section RsTarget.
  • Hi,
    Thanks for your help! It works for me.
    Do you also know how to convert the code below in VSTA code ?
    '// Sync the RobTaget to the VC.<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
        myTask.SyncData("Module1/" + myTarget.Name, SyncDirection.ToController, new System.Collections.Generic.List<SyncLogMessage>());
    '// Sync the path to the VC.
        if (myTask.SyncPathProcedure("Module1/" + myPath.Name, SyncDirection.ToController, new ArrayList()))
            Logger.AddMessage(new LogMessage("SyncPathProcedure of path " + myPath.Name + " succeded!"));
        else
            Logger.AddMessage(new LogMessage("SyncPathProcedure of path " + myPath.Name + " falied!"));
    '// Sync the complete task to the VC.
        if (myTask.SyncToController(new ArrayList()))
            Logger.AddMessage(new LogMessage("SyncToController succeded!"));
        else
            Logger.AddMessage(new LogMessage("SyncToController falied!"));
    Regards,
    Stijn2010-03-28 18:52:45
  • apox
    apox ✭✭
    looks like C# code. VSTA uses .NET means you can use c# as well as visual basic. i am not familiar with visual basic but it if youa re it shouldn t be that hard to to convert it to visual baisc.
    apox2010-03-29 00:37:14
  • Hi,
    as Apox said you can create both C# and VB.NET projects in VSTA.
    If you want to translate the code you can try this tools that provides translations in both directions;
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
