6620_LX Multimove
how can i simulate a multimove-system of two 6620_Lx- on one Jet-Axis like shown in ABBs-promotion video toploader_091201.wmf ? I use RS 5.12.03 wich library includes just a single system?! Where can i get a double system side mounted and one for inverted mounted ?
Thanks.......
dust2
Thanks.......
dust2
Hello,Create a New Empty Station. Just create 2 individual systems or 1 multimove with 2 drive keys via Offline System builder. Make sure that when you startup the systems for the first time that the you make the linear axis mechanisms the same length, hieght and number of legs. You will want one to have the controller on the right and one on the left. You will then have 2 systems occupying the same space but it will look like 1 linear axis. I attached a pacngoBR Jim
j_proulx2010-04-09 23:30:350 -
Thanks Jim,it works fine for me!dust20
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
