Robot Ware Upgrade
I was told when you update Robot Ware on IRC5's you need to request a new license key sting or you may have problems. Is this true?
It depends on the new vertion !
If revition number is the same then it is OK to use the old key.If you for instance have 5.06.05 and upgrade to 5.06.06. or 5.06.07 and so on.But if u go from 5.06.05 to 5.07.05 the I recommend you to read the releasinfo on the CD.from 5.08 and above some system need more memory or a new computer. read release information and send a question to ABB-support to be sure. Some new revisions can support old hardware, but somewhere in a revision track it will not work.if 5.05.05 work ok for you and then you upgrade to 5.05.06 then your system may not work, but a later correction in 5.06.07 it is ok for your system once again and works fine! use the latest build release in your software track.best regardsHenrik P0 -
Thanks for the info and not sure if you know or not but I'm having NFS communication issues during a backup to a remote server with a couple of robot's that have updated robot ware from 5.10 to 5.11 and was wondering if that might be the cause?0
- 367 IRC5
- 858 RAPID Programming
