Can I have a pratical case?
I am confused a long time with how to use "Visual Studio Tools for Applications".I just build a new project,then how to ?Because of not achieving some fuctions of ourselves,I need to use the "Add-Ins".But till now,I am not using.Can I have a pratical case?Would anybody provide a example?Or tell me some basic use? Thank you!
  • Kevin
    Kevin ✭✭
    Hi candy,
    You will find some examples under the 'Contents' tab in APIDocumentation.chm.
    On my machine this is in 'C:Program FilesABB Industrial ITRobotics ITRobotStudio 5.12Help'
    Regards,
    Kevin
  • Select
    VSTA->File->New Project->Visual C#->RobotStudioSample->SampleRobotStudioAddIn.
    Then
    Build->Build SamplRobotSTudioAddin
    Go to RS
    In the AddIn tab, you see the sample menu and in the browser you will see the sample macros if you browse to the current addin.
    ABB
