Can I have a pratical case?
candy
I am confused a long time with how to use "Visual Studio Tools for Applications".I just build a new project,then how to ?Because of not achieving some fuctions of ourselves,I need to use the "Add-Ins".But till now,I am not using.Can I have a pratical case?Would anybody provide a example?Or tell me some basic use? Thank you!
Hi candy,
You will find some examples under the 'Contents' tab in APIDocumentation.chm.
On my machine this is in 'C:Program FilesABB Industrial ITRobotics ITRobotStudio 5.12Help'
Regards,
Kevin
Select
VSTA->File->New Project->Visual C#->RobotStudioSample->SampleRobotStudioAddIn.ThenBuild->Build SamplRobotSTudioAddinGo to RSIn the AddIn tab, you see the sample menu and in the browser you will see the sample macros if you browse to the current addin.Henrik Berlin
ABB0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
