change the speed of the robot in automatic mode
hey all,
we have the problem. that operators are changing the speed of the robot (irc5) while he is in automatic mode.
I have found how to bring the speed back to 100% if you are switching from manual to automatic mode...... but I don't know if it is possible to block a "speed - change" while the robot is in automatic mode....
anyone an idea?
thx,
bart
best regards,
bart
bart
hey
all,I've figured out that this is
relatively easy to do with the UAS (user authorization system).there is only one more problem I
have:In order to get the robotstpeed to
100% if the robot is switched from manual to automatic, I have set following in
the sys.cfg file:#
AUTO_COND_RESET:
-name
"AllDebugSettings" -reset "No"problem is now that beside getting
the speed again on 100% the program pointer also returns to the main
module...... and this is something I don't want....Anybody an idea how I can solve
this?thx,
bart
best regards,
bart0
- 360 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
