Gripper perform mechanism at certain position
tankus
hi, guys, I'm using gripper mechanism to pick up a pin and put it in a pallet. I have set up the mechanism and I/O signal, but I don't know how to make the gripper at certain position and attach the pin to the gripper, can someone help pls, a lot of thx!
you need to create an event with an attach action and connect it to your signal. See Simulation Tab --> EventManager. Once connected your signal to this event set your signal in rapid and the event will be executed. (Same for detaching).
thx for replying, but how do i set the signal in rapid?
In case of a digitial signal:
SetDO SIGNALNAME, 0;
SetDO SIGNALNAME, 1;
have a look into the rapid manual.
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
