second reference
Diede
< ="-" ="text/; =utf-8">< name="ProgId" ="Word.">< name="Generator" ="Microsoft Word 12">< name="Originator" ="Microsoft Word 12">
Hy,
How do you
attach targets to a second reference.
When you move the second reference the targets move along with it.
grts
If I understand you correctly, you want to use the same target (robtarget) with two differents workobjects? This must be defined in RAPID and then synced to the Station.The targets will be moved with their parent workobject. (When you have two instances of the same robtarget data, then you will see two frames in the graphical view).Henrik Berlin
ABB0
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 826 RAPID Programming
- 10 AppStudio
- 105 Collaborative Robots
