Call Screenmaker DLL from RAB
This is an extract from FlexPendantSDK application manual.Launching custom applicationsThe launch service can be used to launch another FlexPendant SDK application.
The name of the proxy assembly along with the fully qualified class name should be used as arguments.VB:
If Not (Me.iTpsSite.LaunchView("TpsViewCustomApp.gtpu.dll", "ABB.Robotics.SDK.Views.TpsViewCustomApp", Nothing, True, Me.cookieUser) = True) Then
GTPUMessageBox.Show(Me, Nothing, "Could not start User application")
Return
End IfC#:
if (this.iTpsSite.LaunchView("TpsViewCustomApp.gtpu.dll", "ABB.Robotics.SDK.Views.TpsViewCustomApp", null, true, out this.cookieUser)!= true) {
GTPUMessageBox.Show(this, null,"Could not start User application");
return;
}If you want to launch ScreenMaker application it can be done like thisif (this.iTpsSite.LaunchView("TpsViewCustomApp.gtpu.dll", "ABB.Robotics.SDK.Views.MainScreen", null, true, out this.cookieUser)!= true) {
return;
}Where ABB.Robotics.SDK.Views.MainScreen is the screen which has been set as mainscreen in ScreenMaker application.You can also refer to the link mentioned below to get more information:Thanks0 -
Hello,yes this works fine, but the screenmaker app is visible in ABB menu. I want this function with a invisible screenmaker app. Reason: I use three to five apps. There is not enough space in the ABB menu!granale0
To test the application on flexpendant the assemblies must be downloaded to the system or home directory of the robot controller. On startup of flexpendant the application assemblies are loaded from the controller and appear on the flexpendant ABB Menu.
I doubt there is a way to avoid the application from appearing in ABB Menu and call it from some other location other than HOME/System directory of the controller.Thanks0 -
Hello,Just to add to what i have already mentioned it is not possible to directly hide the ScreenMaker application from FlexPendant ABB menu through Screenmaker UI.But there exists a workaround to your scenario :It involves modification of the ScreenMaker Project file with the extension (.smk)
1.Open the .smk file.
2.Go to the <TpsViewInfo> attribute
3.<StartPanelLocation> attribute needs to be modifiedBy default it looks like this with value as "1"
<StartPanelLocation>1</StartPanelLocation>4. Inorder to hide the application from ABB menu, change the value to "2"
<StartPanelLocation>2</StartPanelLocation>5. Open the Project in ScreenMaker, Build and Deploy the project to the controller.NOTE:*Setting the value to StartPanelLocation as "2", makes the application incompatible with RobotWare releases older than 5.11.01*It is not recommended to modify the .smk file unless really needed. Please save a copy of the original file before making the changes.This feature will be incorporated in a future release of ScreenMaker so that changes to the .SMK file is not neededThanks0
- 367 IRC5
- 858 RAPID Programming
