I/O conections
veiga144
Hi folks, i have 2 robots in my system and i want use first robot, digital output as the second robot digital input. How can i do that?
i have created the DO in robot1 and DI in robot 2, how to sychronize it?
many thanks,
Jorge Filipe Veiga
ISEP
RS views the controllers as 'Smart Components' and their I/O signals can be connected using the 'Signals and Connections' tab of the 'Station Logic' , see below.
thank you very much! :P my problem is solved!
Jorge Filipe Veiga
ISEP0 -
hum there is a problem wen i run the program apears this error message:projecto 1.3: I/O Connection failed to set 'PosiA?ao_pintura_1' (C0048416) 03-06-2010 14:43:46 General
Jorge Filipe Veiga
ISEP0 -
this error apears too:Not all I/O signals are valid. Failed to get their data. 03-06-2010 14:47:14 General
Jorge Filipe Veiga
ISEP0 -
solved.. :P
Jorge Filipe Veiga
ISEP0
- 304 PowerPacs
- 356 IRC5
- 75 OmniCore
- 850 RAPID Programming
- 26 AppStudio
