S4Backup [WebWare SDK]
I have a problem.
What shoul I do to have this backup done in my pc ?
I wonder if someone could help me with the backup method.
When I use something like this :
dia = Format(Date, "ddmmyy")
    NombreFichero = dia
    status = FrmBG.robotHelper.S4Backup(NombreFichero, 3, resultid)
    If status <> 0 Then    ' did the function work?
        Error_msg status, ""
        Exit Sub
    End If
then I get the error -5108 General error for log
I want to use s4backup method only works on the local memory device and then to be copied in PC with S4FileCopy.But not work. What happen?
  • 1.Which WebWare SDK build version, for instance 3.02.0317, is in use?
    Webware SDK Release 3.2
    2. Are you using long file names on the robot (longer than 8+3 characters) ?
      file name=140905
    3. What are your settings for the following Interlink Configuration properties:
       a. Alias name = R_1994
       b. TCP/IP node and IP address =localhost
       c. Profile name =R_1994
    4. Describe the configuration of robot, i.e. BaseWare version, software options, robot type, etc.
     BaseWare 512
    Robot type= IRB 4400
    FactoryWare, Ethernet FTP, English, Multitasking, Advanced Function, Profibus DP Master/Slave
