Write a Robtarget Help !!!
Dim c As New Controller()
Dim motion As MotionSystem = c.MotionSystem
Dim mech As MechanicalUnit = motion.GetActiveMechanicalUnit()
Dim robP As RobTarget
robP = mech.GetPosition(CoordinateSystemType.WorkObject)
Dim rdRobtarget As RapidData = c.Rapid.GetRapidData("T_ROB1", "SrvSysInit", "ptest")
Dim rtValue As RobTarget = DirectCast(rdRobtarget.Value, RobTarget)
rdRobtarget.WriteItem(robP)
i want to change ptest robtarget position to my current robtarget position but always an error not change my ptest robtarget what is the problem please help
Please post the error text.
Lennart H0 -
error code isobject reference not set to an instance of an objectSee the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************
Message: Object reference not set to an instance of an object.System.NullReferenceException: Object reference not set to an instance of an object.
at ABB.Robotics.Controllers.RapidDomain.UserDefined.FillFromString(String newValue)
<--ABB.Robotics.InternalException at FillFromString in ABB.Robotics.Controllers.RapidDomain.UserDefined
at ABB.Robotics.Dcl.ExceptionHelp.ReThrowException(String objStr, String method, Exception exception, String[] additionalinfo)
at ABB.Robotics.Dcl.ExceptionHelp.GenerateException(String objStr, String method, Exception exception, String[] additionalinfo)
at ABB.Robotics.Dcl.ExceptionHelp.GenerateException(Object obj, String method, Exception exception, String[] additionalinfo)
at ABB.Robotics.Dcl.ExceptionHelp.GenerateException(Object obj, String method, Exception exception)
at ABB.Robotics.Controllers.RapidDomain.RapidData.ReadItem(Int32[] index)0 -
Are you trying to write to a RobTarget stored in an array? I put you the question because the WriteItem method is used when writing to a specific RobTarget that is stored in an array of RobTargets.
If this is not the case please find below code (C#) that will read the current position of the manipulator and then writes the data to a RobTarget variable.
m_MotionSystem = this.controller.MotionSystem;
m_MechanicalUnit = m_MotionSystem.ActiveMechanicalUnit;
RobTarget CurrPos = new RobTarget();
RobTarget rt = new RobTarget();
RapidData rd = this.controller.Rapid.GetRapidData("T_ROB1", "sample", "pTest");
CurrPos=m_MechanicalUnit.GetPosition(CoordinateSystemType.WorkObject);
rt=(ABB.Robotics.Controllers.RapidDomain.RobTarget)rd.Value;
rt = CurrPos;
this.m_master = Mastership.Request(this.controller.Rapid);
rd.Value = rt;
this.m_master.Dispose();Lennart H0
- 341 IRC5
- 68 OmniCore
- 839 RAPID Programming
- 18 AppStudio
