How to manage a variable?
I'd  like to manage a variable in SM.
For example,
image to have a rapid num Speed:=10.
I'd like to push a button and  icrease this value,
for example  by  5.
then  if the Speed reach 100, I'd like to reset this value to 0.
How can I do  this?
(Call .net method? how to  pass the current value to the method?)
Can I have an  example?
BR
Oscar
BR
Oscar Ferrrato
  • Hello,
    You can refer to ScreenMaker chapter in RobotStudio 5.13 Help documentation
    Search for the keyword 'Call .NET Method' in search tab.
    Steps are defined describing usage of Call .Net Method.
    I have attached a project which would help you out. The return value of the your method would be the value being passed as paramter. Bind the value to an application variable.
  • Thank you for the example.
    Now  I'll take a look on it.
    Just a comment, I cannot  find  anythink about  .net Method in RS 5.13.1  help on line
    Oscar
    BR
    Oscar Ferrrato
  • Thanks.
    I did it  work.  I forgot  to  write again my rapid variable after the  method code.
    (about the manual- I find the content, the problem was that the help  search it was not  working. I find it  searching it  manually...)
    BR
    Oscar Ferrrato
