System module
Xin-H
I just wonder what kind of program can be in the system module. and what kind of computer language are these programs written in?Is there any one know about this?
xin
Hi Xin,
As I understand it you can put exactly the the same code into a system module as you can into a program module the difference is how system modules are treated by the controller.
The following extract is from the Rapid manual:
System modules are used to define common, system-specific data and routines, such as
tools. They are not included when a program is saved, meaning that any update made
to a system module will affect all existing programs currently in, or loaded at a later
stage into the program memory.
Hope this helps0 -
Thanks a lot Graemexin0
- 303 PowerPacs
- 352 IRC5
- 849 RAPID Programming
- 24 AppStudio
