Launch RobotWareArc View from custom Application
I tried to launch the "RobotWareArc GUI" from my custom application , but it doesnA't work.
According to the SDK Reference Guide it should be possible , maybe i do something wrong.
Has someone done this before ?
This is my code :
private void btnRobotWareArc_Click(object sender, EventArgs e)
try
if (iTpsSite.LaunchView("TpsViewArc.dll", "ABB.Robotics.Processes.Arc.ArcViewDesktop", null, true, out _cookieD) != true)
GTPUMessageBox.Show(this, null, "Could not start User application");
return;
catch (Exception ex)
GTPUMessageBox.Show(this, null, ex.ToString());
  • Hi
    I'm a bit confused...Can you please tell me:
    -In which manual did you find this?
    -Which is the version of the manual?
    -In which section/page did you find this.
    Thanks!
    Lennart H
  • Hi,
    This can be found in the "FlexPendant SDK Reference guide" located at C:Program FilesABB Industrial ITRobotics ITSDKFlexPendant SDK 5.13
    Search for  => ITpsViewLaunchServices.LaunchView method
    It now works , i was missing some code in the ITpsViewSetup.Install method.
