RapidData binding problem
charon
in ScreenMaker
i try to change text property of a TpsLabel by binding it to a controller object. I create persistent string datas as described in video tutorials. ScreenMaker build project and deploys it to VC with no problem but my application cant read any rapid variable from VC.
I have no problem with reading signal values from VC. I add a LED object to project and bind it to controller signal source(MOTLMB sys signal) and it works and refresh its value normally.
i use RobotStudio 5.13.02 on XP SP3 PC
Station : webwiz/2167/SMDemo1.rar
SM Project : webwiz/2167/SMExample.rar
charon2010-10-31 18:17:28
Erdem Karaçeper
Do you get any error message box in Virtual FlexPendant on opening the application ?What is your system language and OS settings (English or Turkish or anyother) ?Thanks0 -
i dont get any error messages when i run my application on VC.
My system language is English.(only my input language is set to TR keybord) By the way i try to add a DataEditor to my application and connect it to a Controller num data (persistent) but when i click to object it throws an exception like in the screenshot.
Message: Object reference not set to an instance of an object.
System.NullReferenceException: Object reference not set to an instance of an object.
at ABB.Robotics.Controllers.RapidDomain.RapidData.Read()
ABB.Robotics.InternalException at Read in ABB.Robotics.Controllers.RapidDomain.RapidData
at ABB.Robotics.Dcl.ExceptionHelp.ReThrowException(String objStr, String method, Exception exception, String[] additionalinfo)
at ABB.Robotics.Dcl.ExceptionHelp.GenerateException(String objStr, String method, Exception exception, String[] additionalinfo)
at ABB.Robotics.Dcl.ExceptionHelp.GenerateException(Object obj, String method, Exception exception, String[] additionalinfo)
at ABB.Robotics.Dcl.ExceptionHelp.GenerateException(Object obj, String method, Exception exception)
at ABB.Robotics.Controllers.RapidDomain.RapidData.get_Value()
at ABB.Robotics.Tps.Windows.Forms.EditValueServiceProvider.Init(RapidData rapidData, Int32[] index, String txtValue)
at ABB.Robotics.Tps.Windows.Forms.EditValueServiceProvider.EditValue(Control childControl, PropertyDescriptor propertyDescriptor)
at ABB.Robotics.Tps.Windows.Forms.DataEditor.OnClick(EventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
BR.
charon2010-11-01 14:30:48Erdem Karaçeper0 -
Hello,Try it on a system with the input language also as English. And then launch VirtualFlexPendant.This may be language specific issue.Thanks0
Hi Abhishek,
After i switch to input mode English application start to read RAPID data.
Thanks.
BR.
charon2010-11-01 17:07:03Erdem Karaçeper0
