Add instruction "pPut.trans.y:=" with Flexpendant
EFG
In one of mine existing programs I've got a instruction "pPut.trans.y:=332.8".
In another program I would like to add the same type of instruction (pPut.trans....) through the Flexpendant, but I can't find it. Obviously I can copy and paste, but I'd like to add it from scratch.
Is it possible to add the instruction through the Flexpendant, or do I have to do it offline?
If you connect a PC with RobotStudio installed to your robot, you can do it from the RobotStudio Online editor.
[QUOTE=Anders S]
[/QUOTE]Yes I know, but I would like to do it directly from the Flexpendant, if it's possible.0 -
you can type any instruction at all using the abc edit function and the onscreen keyboard.I think you can start with the := symbol and then select pPut, but from memory you probably have to type the .trans.y0
[QUOTE=mattdavis]you can type any instruction at all using the abc edit function and the onscreen keyboard.I think you can start with the := symbol and then select pPut, but from memory you probably have to type the .trans.y[/QUOTE]I have that idea as well, I think I'll go with that! Thanks!0
I found the way to add the trans.y (by mistake ironicly), see attached picture.0
- 360 IRC5
- 77 OmniCore
- 852 RAPID Programming
- 30 AppStudio
