Ordering system actions??
Is it possible to order system actions from Flexpendant SDK? As far as I can tell, the only possible way is via I/O signals that have already been assigned system actions in the system parameters? I am using v.5.06.
Thanks.
Technical Support Engineer
Robotics Product & Systems Service
Manufacturing Automation, Automation Technologies (ATMA)
ABB Australia
Email: michael.siminski @ au.abb.com
Can you be more specific about what you mean by system actions?Russell Drown0
Turn motors on/off, start rapid program from main/current position, reset errors, etc.
Thanks.
Michael Siminski
ABB Australia
Email: michael.siminski @ au.abb.com0 -
There is no special functionality in FPSDK for these functions, as you say you might be able to use I/O mapping to access them.
Part of the reasoning for this might be that most those functions are right on the GTPU anyway, if not directly through a dedicated button then through one of the programmable buttons.
For programmatic access to these functions you might look towards CAPI (part of RAB) or WebWare SDK. This access would be remote, however, i.e. running on another PC on the network.
Russell Drown0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
