Error message [WebWare Server]
Hi Ronny
When do you get this error???
Per Svensson
Company Specialist
I get the error when trying to connect to the server.(From my laptop)
Punching in the ip +/webware, this message is the only thing that happens.
Hello Ronny,
It appears that you are trying to access your WWServer using a UNC path. It is necessary to access it using a url. If WebWare Server was installed using the default configuration, it is a set up as a virtual directory and can be accessed by entering:
http://<serverIPaddress>/webware
You may substitute the server host name if it is resolvable by your PC, but theIP address should always work.
RussD37957,6834490741Russell Drown0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
