UIShow error. TypeName incorrect.
jesus
in ScreenMaker
Hello.
I have a small problem with an application and the instruction ScreenMaker RAPID UIShow.
I created a simple application in FlexPendant generated whith ScreenMaker. This application works perfectly and runs perfectly from the ABB menu.
The problem comes when try to run this application from a UIShow RAPID instruction. The FlexPendant shows the event message 41664 "The typename is invalid for this assembly." The example 1 in the RAPID reference manual is used for testing. The TypeName "ABB.Robotics.SDK.Views.TpsViewderechoCorto" use in the routine down, which I believe is causing the error.
PERS string Name:="TpsViewderechoCorto.gtpu.dll";
PERS string Type:="ABB.Robotics.SDK.Views.TpsViewderechoCorto";
PERS string Cmd1:="Init data string passed to the view";
PERS string Cmd2:="New init data string passed to the view";
PERS uishownum myinstance:=0;
VAR num mystatus:=0;
PROC SDK_visible()
! Launch one view of my application "derechoCorto"
UIShow Name, Type InitCmd:=Cmd1 InstanceID:=myinstance Status:=mystatus;
! Update the view with new init command
! UIShow Name, Type InitCmd:=Cmd2 InstanceID:=myinstance Status:=mystatus;
This is the image that shows the FlexPendant when the error occurs:
Does anyone know what may be causing the error?.
Thanks in advance.
Jesus Gil.jesus2010-12-15 20:54:45
PROC SDK_visible()
Thanks in advance.
Hello jesus,Kindly take a look at this post which provides you with information as to how the type should be defined for screens created using ScreenMakerThanks0
Is perfect.
Thank you very much for the prompt assistance and solution to my problem.
Thanks.
Jesus Gil.
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 737 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
