Picking from a tracked conveyor.
Hello All,
I have been working with understanding the Smart Components and Conveyor tracking recently and I am not able to pick up an item off of a conveyor being tracked.  Is this a limitation? If not, how can I add more parts to the tracked conveyor.  I do not believe this is a common application but I just want to know RS limitations.
Thank you for your help.
  • Hi,
    You can not attach/detach objects when you use conveyor tracking (workobject moved by the conveyor) in RobotStudio.
    ABB Robotics
