the task frames in the MultiMove system
abood
Hi ,
I have built a MultiMove system with two robots in RobotStudio, everything worked fine except that when I save the station as a pack and go and open it again, I can't run the simulation again, instead it shows an error saying that "Power fail restart failed".
I found that if I set the task frames for the robots to the current values , and then reconfigure the targets in the robots paths, it will run the simulation correctly, but ones I save the station and open it again, I got the same error.
I hope that someone could help me with that.
Thanks,
/Abood
Thanks,
/Abood
Please get in touch with your local ABB Robotics Service representative that can forward your issue to our tech support.Henrik Berlin
Thanks a lot for the respond, actually I managed to find the problem and solve it.
Regards,
/Abood
would bee nice to know how you solved itBest Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
