Mirror of cutouts on carpet [KMT PowerPac]
in PowerPacs
Hello. I am programming a floorcarpet on KMT Cuttingbox. Is there any possibility to mirror the cutouts?
Hello Peter! Use the car-zero-frame as a mirrorplane and then just mirror all cutouts. Normaly you can also re-use middle and rear sections of the outer contour as well#1 Mark you floor carpet, right click and select "set as USC" or "als BKS setzen".#2 Select your path and right click choose path/mirror#3 select UCS / BKS as "reference" and "flip axis Y"Good luck!Best regardsConny0
by the way, see Chapter 3.8b about mirror-function in your training documentation0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
