Adjusting stick-out in ArcWelding PowerPac [ArcWelding PowerPac]
If I change the stick-out for a particular path, does it change the programmed position or the tool tcp position, or something else?
  • Anyone?
  • Hello TomR,
    It will change the target position.
    BR / Henrik
    Kga Offline Center www.kgaofflinecenter.se
    Offlineprogramming and simulation in RobotStudio and ArcWeld PowerPac
