Load geometry
Is there any way I can make RobotStudio remember not to load the geometry for specific libraries? If not, is there any way I can "unload" geometry for a library that has already been loaded?
I have tried to setup a station where I unchecked the "load geometry" checkbox when importing libraries. But the next time I start the station the geometry is loaded.
  • If you load a station with the "Load Geomeotry" check box UNCHECKED, then Save or SaveAs a new file name (if you do not want to loose the original geometry) and you will get a warning, explaining that the geomoetry will be lost when saving...
    Click YES - then the next time you open that station, the geomotry will not be loaded, because it was saved without geometry loaded.
    Thomas J2011-02-09 17:09:07
    Thomas H. Johnston
    PACs Application Engineer
  • If you want to be more selective, you can "Disconnect" your library, right-click it in the browser, and select "Remove Geometry", then "Save As Library" again.
    ABB
