program abb robot to write A-Z using robostudio
lilcuzi
hey guys,,.
i hav been trying to use robot studio software to
program an ABB robot irb 1400 to write alphabets from A - Z. i'm having
problems in programming the character writings...
any help will be appreciated..
thanks..
thanks..
Hy lilcuziWhat do you meen by: write alphabets? Does the robot have a pencil and has to draw the letters?Best regards0
You should consider using some kind of CAD software to type the letters, export the curves (or surfaces) outlining the letters, import them into RobotStudio and use the "Create Path From Curve" or "Path from Edge" functions to generate the robot program.Henrik Berlin
thanks henrik..i will try that..
thanks..
actually yeah., the end effector has a pen attached to it. i am to make the robot to do curves and write the letters. u got any suggestions..?
thanks
Hi lilcuziI have a suggestions for a manual way.You could create a body with the picture that contains the text in a JPG-File and create manualy targets.Create a big flat box:Modeling / Solid / BoxRight klick on the box an select: Graphic Appearance...Under Textures / Base Texture you can select on ... the image file.You can manualy go to the edge of the lettres and create targets. Then you can create paths with MoveL or MoveC for each lettre.Best regardsMarcel0
thanks marcel. i will do that. it should be the same with importing geometry from a CAD software e.g solidworks cad cam and then create the paths from curves already drawn on the solidworks
Dear Friend,
I also have the same problem. I do not know how to do to read an external file with the sequence of letters, or simple the user types the word to be written in the FlexPendent. Do you have a ready example, some tutorial or link on the web? I need to indicate which DAC should I use if it is even necessary. What help is welcome.
Thanks, Adilson---------------------
ABB IRB-140 with IRC50 -
? hope th?s help u
http://cadblog.info/2011/03/13/how-to-write-in-robotstudioadditional-explanations/
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 25 AppStudio
