I/O singnal
i'm using ABB-1400...and i want to write a rapid program to control a system,how can write a rapid program to control a digital input ?
  • Check the manual "Introduction to RAPID" that is available in RobotStudio.
    ABB
  • thanks for your reply henrik..
    i'm confused with unit mapping when creat a signal,i want to add a digital input in  i/o board ,in label x4:1  .and confused with setting the  unit mapping  value .how can i set this data
  • i fixed the problem .thank you anyway :)
