Background task does not update I/O window
Kevin
My background task resets some digital outputs when power to process tooling is killed, for example by an emergency stop. This prevents the tooling from starting unexpectedly when the power is re-enabled.
If the operator tries to switch on one of these outputs via the Flexpendant 'Inputs and Outputs' window while the power is off, the output status displays as '1' although the background task has reset the output. It is necessary to scroll down/up or switch screens to refresh the display.
Is there a way for the background program to force the screen to refresh after switching an output?
Thanks,
Kevin
Thanks,
Kevin
Hi Kevin,The question is concerned with the FlexPendant, so I move the topic to the RobotWare forum.Henrik Berlin
I suggest you contact your local ABB Robotics Service representative and ask them to log a support request about your issue.Henrik Berlin
ABB0
