Page designation
hello mates..
I would like to open (show) a designated page, when I turn on the flex pendant (controller). Does anybody know how to do this kind of function??
thank you in advance!!
spaik
you can let the system launch your application when changing the operating mode of the controller. This also works when you start-up the controller.
On the FlexPendant, go to Control Panel/System/View on operating mode change; and enter the requested information.
Unfortunately, it seems that there is a bug in RW5.06 Build95 and this is not working right now. I created a PDD and let you know when I have new information. (or you just give it a try; maybe I did something wrong).
It is not possible to show a designated window of your application, only launch it.
best regards
Ren?
you have to enter the following in Control Panel/Systems/View on op mode change to let your application start-up automatically (when the controller starts-up):
Dll:
TpsViewXXX.gtpu.dll
Type:
ABB.Robotics.SDK.Views.TpsViewXXX
Where XXX is the name of your app. Use TpsViewType.Static in your application to avoid that multiple instances are created.
BR
Ren?
