Views for operating state
there is a bug in RW5.05, therefore an SDK Application (running in the SDK Domain) is not launched although configured correctly in the Control Panel / System.
This should be fixed in Rw5.06, but I had no time to test it (yet).
BR
Ren?
you have to enter the following in Control Panel/Systems/View on op mode change to let your application start-up automatically (when the controller starts-up):
Dll:
TpsViewXXX.gtpu.dll
Type:
ABB.Robotics.SDK.Views.TpsViewXXX
Where XXX is the name of your app. Use TpsViewType.Static in your application to avoid that multiple instances are created.
BR
Ren?0
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
