Adding new robot models
How do I add new robot models to RS? I have put the new IRB760 rslib file in the folder but do not have a template file so cannot create a station from template.
Andrew Goddard
  • Hi,
    First create a system with System Builder.
    Then open an empty RS station and add existing robot system.
    RS will now ask you for the robot model.
    BR / Henrik
    Kga Offline Center www.kgaofflinecenter.se
    Offlineprogramming and simulation in RobotStudio and ArcWeld PowerPac
  • Hi Henrik
    I have tried to follow the instructions.
    I have created a system with virtual key and have selected 'addional motors or no IRB manipulator' as selecting anything else brings the selected manipulator into the station.
    I then selected 'new station' and selected 'existing system' and selected my saved empty station with the system I configured.
    The virtual controller starts however I am not prompted to select a robot model.
    I have tried importing the library file however the manipulator does not link to the virtual controller.
    Am I missing something?
    Andrew
    Andrew Goddard
  • webwiz/3754/system.rarHello Andrew,
    I am no expert in IRB760 but I have done tests like this before with other robots.
    I did a small test and RS asked me for the robot model.
    I send you the xml option list that I tested.
    I am not sure if it is okay but you can try.
    BR / Henrik
  • Hi Henrik
    I have sorted it. I had the wrong version of RobotWare. You need 5.13.03 which has the IRB460 and IRB760 to select in the manipulator list.
    Andrew Goddard
  • Perfect!
    BR / Henrik
