Problem with c-start
Hi, I tried to do a c-start, with bootmedia on a USB-device. But the controller restarts and loops throu 3 different screens, one saying: "Connecting to the robot controller", the other one saying "Loading image from robot system" and the last one says "Bootloader V2.08: decompressing image"
How can I get out of this loop, and get the system up and running again?
hmmmm. It seems that there is a hardware failer..Have you tried to load the bootmedia fram a PC connected to the service port?I think you should contact your local ABB service center if that doesen't workBest Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 367 IRC5
- 858 RAPID Programming
