Move robot with keyboard entry
RussG
Hi All,
In RS versions 3-4 there was a window that you were able to view the mechanisim rotaton and position. This wa really convinient for positioning the robot and teacing in targets. Is this available in version5.xx ?
RUSSELLgee
Director
1/118 Connaught St Sandgate QLD Australia 4017
ph +61738694298
fax +61738693284
mob +61418116644
email russell@manmac.com.au
Director
ph +61738694298
fax +61738693284
mob +61418116644
Hi,If you right click on the robot in the layout tab there is an option about half way down (see screen shot below) Mechanism Joint Jog and Mechanism Linear Jog.You can click on the sliders and type a value, drag the slider, or use the step buttons on the right hand side.RegardsGraeme0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
