Process Time Calculation
Dear Sir,
I have completed simulation on an industrial component on robotstudio. Now I want to optimize the cycle time. How can I vary process time with variation of speed. Please Guide me.
Thanks.
Regards,
Thanks.
Regards,
VASUDEVA
Dear Vasudeva
This is the program example of how to calculate the cycle time :
MODULE MainModule
VAR clock clk1
VAR num clk01
PROC main( )
rResetClk;
rStartClk;
........ (robot movement on 1 cycle)
rStopClk;
rShowClkTime;
Local PROC rResetClk ( )
clk Reset clk1;
Local PROC rStopClk ( )
clk Stop clk1;
Local PROC rStartClk ( )
clk Start clk1;
Local PROC rShowClkTime ( )
clk01 := clk Read (clk1);
TPWrite "Cycle Time Robot is = "
um := clk01;
I hope this will help
BR
Dhyan W
fear of GOD is the beginning of wisdom0 -
I have tried various ways to calculate time with robostudio for my pallet wrapper equipment. But no luck with it. I need someone to help me here, please. allanjames2011-06-28 14:32:110 -
To make it virtual, you will need to make a virtual controller. The other commenter seems to think you already have a VC setup, or you are running on active equipment. But the way you are writing, it sounds to me like you are not running any active process. As to how to set up a VC, I don't remember. There are guides available on google, but not the most straight forward.0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
