RS Trail
megatooL
hi buddies,
i wanted to confirm if the create mechanism function is disabled in the 30 day trial of RS 5.13??
Do not fear to be eccentric in opinion, for every opinion now accepted was once eccentric..
IT is not disabledBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
i tried creating a mechanism... but afte i defined the links and the joins... the next step wont come... to set the transitions n alll.. !!
Do not fear to be eccentric in opinion, for every opinion now accepted was once eccentric..0 -
After links and joints you have to compile your mechanism. If you can not find the button you have to maximise mechanism box because there seems to miss a scrollbar in the right side of the window to scroll down to the compile button.Had same problem to find the compile button.A tiny irritable bugBest Regards
Klaus Soenderhegn
well... i got the button thanks... i was tryin to make a gantry mechanism.. X & Z... defined the links and the joints correctly... but when i click on compile... it gives an error.. i tried with external axis & device also.... but stil no luck.... pls help.... thanks...
Send a pack&go to my email and i will investigate it.ks(a)cadalysator.dkBest Regards
Klaus Soenderhegn
sent you the mail..
got the mail but in denmark we have hollyday so i'm working in my garden.
.I will look into it later.Best Regards
Klaus Soenderhegn
oops... okay.. :P
but pls do..
From the picture it seems as if the mechanism is defined as a Device. If you want to run it with the StandAlone Controller you should define it as a Robot. If you want to attach the robot to it and use it as an external axis you should define it as an External Axis. (Device should of course work, but may not be the right choice for you anyhow).
Henrik Berlin2011-04-26 12:28:47Henrik Berlin
ABB1 -
Hey.I had no problem with compiling ypur mec.Have send you the result on emailBest Regards
Klaus Soenderhegn
www.cadalysator.dk1 -
It will not be disabled. Maybe their is something wrong with the software. Try to download and re-install it.
