RS Trail
hi buddies,
i wanted to confirm if the create mechanism function is disabled in the 30 day trial of RS 5.13??
Do not fear to be eccentric in opinion, for every opinion now accepted was once eccentric..
  • Klaus
    Klaus ✭✭
    IT is not disabled
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • i tried creating a mechanism... but afte i defined the links and the joins... the next step wont come... to set the transitions n alll.. !!
  • Klaus
    Klaus ✭✭
    After links and joints you have to compile your mechanism. If you can not find the button you have to maximise mechanism box because there seems to miss a scrollbar in the right side of the window to scroll down to the compile button.
    Had same problem to find the compile button.
    A tiny irritable bug
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • well... i got the button thanks... i was tryin to make a gantry mechanism.. X & Z... defined the links and the joints correctly... but when i click on compile... it gives an error.. i tried with external axis & device also.... but stil no luck.... pls help.... thanks...
  • Klaus
    Klaus ✭✭
    Send a pack&go to my email and i will investigate it.
    ks(a)cadalysator.dk
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • sent you the mail..
  • Klaus
    Klaus ✭✭
    got the mail but in denmark we have hollyday so i'm working in my garden. Wink.
    I will look into it later.
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • oops... okay.. :P
    but pls do.. :)
  • From the picture it seems as if the mechanism is defined as a Device. If you want to run it with the StandAlone Controller you should define it as a Robot. If you want to attach the robot to it and use it as an external axis you should define it as an External Axis. (Device should of course work, but may not be the right choice for you anyhow).
    Henrik Berlin2011-04-26 12:28:47
    ABB
  • Klaus
    Klaus ✭✭
    Hey.
    I had no problem with compiling ypur mec.
    Have send you the result on email
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • It will not be disabled. Maybe their is something wrong with the software. Try to download and re-install it.
