No Restore for real Robot Cell
CASE1:
Operatin Mode <250mm , no Paraeters are loaded in Virtual Robot Browser.
After entering the Programmers Code in Restore Menue, the TeachPendant shows Error 12033. Error restoring configuration parameters (MMC.cfg) ????
Case2:
Operatin Mode <250mm , all Paraeters are loaded in Virtual Robot Browser.
I can go on the TeachPendant to Restore Menue, select Source directory press Ok and nothing hapens, no Programmers Code, nothing.!!
How the Hell can I create a real existing Robot Cell???
Hello Horn,
Welcome to the SoftWare Support Forum!
From what we can see you are doing everything right.Could you please upload your backup and your Key-String so we can test it?! What version of QuickTeach are you using?
Thank you in advance!
Best regards
/Ulrika Mor?n
Support Engineer
Ulrika Mor?n37964,43150462960 -
Hello Ulrika Mor?n,
I would upload you my backup+Key with pleasure...
but how??
With friendly regards
T. Horn / Programmer
Hello again,
If you zip your backup and use the button at the very right in the "Post Reply" field you should be able to upload things.
Best regards
/Ulrika Mor?n
Support Engineer
- 367 IRC5
- 858 RAPID Programming
