Robot on track
bme
How can I attach the robot to a track so that it is rotated 180 degrees compared to the "standard" position?
Hi,First create a system with robot on track with the robot in the "standard" position.Then open System Configuration and change the Z rotation to 180 deg. for the robots base frame.Press OK and restart the controller. When the controller is restarted you will get a message that says that the Base Frame definition is not the same as in the VC.Click YES, now should the robot rotate 180 deg.Best regards,
ABB Robotics0
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 826 RAPID Programming
- 10 AppStudio
- 105 Collaborative Robots
