use Keystring to setup a VC
Import the correct robot model in RobotStudio, right click on it in the browser and select "Setup Controller".
Select "Change Controller" in the Setup window and then click on "Create" in the Virtual Robot Browser window.
Now can you type in your key string in the "Key String field".
When you have done that press OK and then Finish.
Now have you created a new Virtual Controller from your own key string.
thanks for your answer Mr Anders S
I have try the method you recommanded to me.
but there still little problem. when I type the name of the new system "Sperre" and click "OK",there comes a erro message which says that there is not a map named "Sperre" under the path "c`:programfilerfellesfile`ABBautomationcontrollerV4
obotSperre"But I find the map under this path as you can see in the attachment. I do not know what's happen?erro.rar
xin0 -
It seems to be a problem with your user rights. You need to have at least "standard user" rights when you are using RobotStudio.
Sorry sir ,"standard user" for what ? for my PC or for the RobotStudio?
how can I get a "standard user "right if it is for RS?
xin0 -
I meant the user rights for Windows. Open the Control Panel and select "User Accounts". Here can you see the user rights for different users (accounts).
ABB Robotics0
- 350 IRC5
- 848 RAPID Programming
- 23 AppStudio
